Justin Cider
- Jun 28, 2007
Which fan configuration is better for a Swiftech MCR220.It will be cooling a Q6600 with Swiftech apogee and a MCP-355 pump
I like to push, pull is quieter though.
But, soulless, Water out from 9.2c to 7.6c is almost a 30% gain.
OP: You can typically use 2 fans (on a single rad), at 6v, to equal the airflow of 1 of the same fan at 12v, at about 3dba less per 120mm slot on the rad...
Use cheap fans gutted for shrouds, cost would be around $5 each. You already have the Martinliquidlab.com link so no need to repost that. Go give it a read along with the guides here:
http://www.xtremesystems.org/forums/showthread.php?t=202394
http://forums.extremeoverclocking.com/showthread.php?t=282232
Hmm, well, my case exhausts warm case air, through the radiator, outside. However, the radiator is mounted at the very top of my case, and there are 3 low-speed intake fans that constantly blow cold air into the case bottom... This helps maximize convection, even if it's just a theoretical benefit .
The inside of my case is, at most, 1c warmer than the outside case air...
