Push-Pull fan recommendations for Xigmatek S1283
What are the best pair of fans to put on a xigmatek S1283 for a push pull config?
I was looking at the Scythe S-flex 63.7 CFM @ 28db as my choice.
But opinion from others matter to me also on this set up.
Thanks,
Mark
Unless he duct tapes it. OP didn't set any parameters for a fan either - quiet? don't care? just want as much air as possible?
Actually, I think a push pull config would only benefit if you were using fans that create little air-pressure. You'd be better off getting a single 38mm by 120mm fan. Scythe makes one in 1000, 2000, and 3000 RPM increments. The 1000 is pretty quiet and can push a decent amount of air for it's quietness. Dba measurements are around 19 to 20.
As another has said, you didn't say what type of fan you wanted. You want a screamer? something silent? A good mix?
I have the Noctua fan on my Xig just for push, and it works very well. Great CFM/DBA
