Push or Pull => radiator <=, justification?
CoW]8(0)
It just seems to be preference from what I've seen.
Someone with experience in fluid dynamics might be able to sort this out...
Note that this isn't a question of whether to move air into the case vs moving it out.
i don't think it matters honestly, because no matter which way you have the fans blowing, net airflow and any kind of blockage would be the same... i'm gonna be doing a push setup with my external water cooling rig, but i could turn them around and still have the same airflow and the same temps, it wouldn't matter at all
Most of advice ive seen is to put them in a pull situation. Ive had better temps in this situation also. The reason from what I understand is this allows even movement of air though the rad, vs on the push the air isnt as even across the rad. But as always what ever gives u the best temps, and the best situation for your application.
With that logic you may as well tell people that a single 90cfm fan on a 2x120mm radiator is just as good as a two 45cfm fans. I don't think this works out ;)
Without any other knowledge or a background, I agree with kenpomasta.
almost every high end rig I have seen has had a pulling effect, If you look at any of the production wc rigs they all pull.
$.02 no need for change :p
pushing will have the effect of fighting rebound air turbulance while pulling doesn't. So even with a higher cfm fan, you might still get worst air flow compare to pulling since you will have more rebound air to fight off.
zactly. Pull is better.
I have tried both in my rig and must say that "pull" seems to be the best option for me. On average got about 2-3C better results on my system temps.
Computer fans are not made to fight back-pressure which they get plenty of in a push setup. Set them up in pull. You could always do push/pull, and end the debate.
On the couple of water cooled setups I had, pull always worked better. I tried push, pull and push-pull setups, and by pulling temps dropped a degree or two over pull, and with push-pull setups temps were the same as pull only.
