Here's my setup, the system is in progress since moving from my atc-4000 so no WC until I get more supplies( MCT-5, sealant etc...).
Iam using a lian-li hd cage with 4 drives, its been modified to accomodate a 38mm deep fan however I usually use an extra 120mm to blow over the video card memory and VRM's. This keeps everything nice and cool when wc-ing, assuming I replace the 25mm akasa fan with a panaflo 38mm do I then need the other 38mm fan that push's air over the hard drives?
thermochill PA120.3 (+38mm panaflo's) fitted with no cutting what so ever and no blockage from the PCP&C 510 SLI PSU.
and yes the HD cage is sticking out, thatd currenlty in progress after dremeling and JB welding it to make it slimmer.
