I used to delete it and saw no differences.
What is it their for ? Windowsxp-pro
And whats it do ?
Also if you do delee it as i have in the past it tells you if you want o kepp the files or not. Dont know 100 % what that means exactly other then keeping the files. Wether it might do this or that.
Any elaboration on ASP in laymens terms much app.
And whats it do ?
