Hello fellow members. I'd like to introduce the next case to the PURE family of cases. The specs are as follows:
- Mini-ITX motherboard
- 175mm Dual Slot, Max 25mm over ref. height (including power connector) GPU
- SFX power supply support, External HDPLEX 400 AC-DC support,
- C6 power entry, 12mm power entry
- Max 70mm CPU cooler with SFX PSU
- 2X 80/92mm fan (clearance varies) case fan
- Mounting for 120/140mm when single slot GPU is used
- Powder coated in all matte black, or two tone black + white
- Made in USA, from 1.6mm aluminum
- Ships from USA
