Pure Power Express250 compatible w/ 20pin?
Katotonic
THis booster uses a double headed adatper to plug into my motherboard and then into the main PSU with 24 pins on each side. Unfortunately I have a 20 pin PSU....can I just go ahead and plug that into the 24 pin (it fits) or do I need a 20 to 24 pin adapter?
Stupid question probably, but could use some info.
Thanks for the reply, I actually found an adapter laying around and used, it works fine.
