Pumps interfering with HD's? I know there has been this discussion before, but I have a different plan in mind based on what was discussed here a while back. Just to remind you I have an Aqua Computer Aquastream pump. This is based on the Eheim 1046 and is actually a 9 volt alternating current pump. The 12 volt direct current goes into the Aquastream controller and the resulting signal sent to the pump is alternating current if this might make a difference. Aqua Computer sells a pump shroud called a FMJ (Full Metal Jacket) for the Aquastream.
Question: Is having the AC pump in such proximity to the HD's going to cause any distortion of my data from the alternating magnetic field surrounding the pump body? I already have a FMJ, but kind of like the look of the pump and don't really want to use it. Ideas?
If it matters, those are 74Gb WD Raptors watercooled with Koolance HD coolers.
