Afternoon all,
I am going to be watercooling a pair of Socket F 22xx opterons:
I'll be using 2 Apogee GTX blocks in series, and Triple Black Ice Pro III rad with 3x 120mm fans. All pipework will be 1/2", in an attempt to reduce resistance (there will already be a 3 foot head height difference between pump and radiator)
Not sure about pump or res. I was thinking about the WaterChill Xtreme [12V] Integrated Pump/Reservoir from Asetek, but not sure about whether this will be up to the job.
The big issue is that my pump will have to be mounted quite a long way below the mobo, so any reservoir here would have to be pretty water tight. I suppose my other option would be to put a pump there and have the reservoir where my fill port is in the diagram. Any suggestions?
Thanks for your suggestions people
PS: I am using the Lian-Li PC V2100 PLUS Silver Aluminium Full-Tower case. Please don't suggest I get another case!!!
