I am building a computer and I'm trying to use my old pump in my new water loop. Unfortunately, its a huge eheim 1250 (just over 300 GPH) that can't fit inside this case. As a result, I need to get a new pump before I can finish this computer.
My loop is a Dtek fuzion CPU block, a GPU block for a 9800gx2, a 120mm radiator, a T-junction, and of course, the pump.
I see the DD-CPX is very compact and very quiet but the GPS is less than half of the eheim. I am worried that this will not be enough "push" for the components in my loop.
Would the CPX be good enough or do I need to step it up? What do you recommend? Thank you.
