pump problems
Rasha
I started this in another thread, but i thought it best to make it its own entity. I setup my wc system to test for leaks, one leaking item was the pump wich is a danger den pump
http://www.dangerden.com/mall/Pumps/dd12vd4.asp
ill try to follow up with pictures tongiht, the pump worked fine, even with air spots running through it, however it leaked slightly, i fixed the leak by tightening down the bezzel as hard as i could, this stoped the leak and the pump ran fine, then a large section of air came down the hose when i was looking over my res and the motor made a strange noise, then it started shaking and didn't pump anywater even though i actualy got water in it (didn't pump enough water to push through both the cpu/gpu block anway, if i undid the gpu block there was slight water pressure, so i was like what the fuck, i took the pump apart its a magenettically driven motor thats compleately incased by itself, there is a shaft in the middle of the motor with a small ball ontop, the impeller piece which is shaped like an acorn sits in the socket with the shaft sticking through it, both are magnetic. there is a slight scoring on the actual pump but nothing major, if i look on the inside of the propeler there is a gear, in that gear there is a small circle almost like a socket, however its tilted instead of laying flat _ it lays at an angle \. I do not know if that is the way its spost to be, i connected the motor with everything off just for a few seconds it rotated around but it also kinda wobbled, like when a wheel on a car isn't secured properly how it looks like one side is out futher then other and rotates around, and it still makes that damn noise, anyhone have any clue wtf is wrong with my pump
Hmm, I have that same pump and I haven't experienced anything like that. You may want to email Laing or Danger Den and see what they have to say. Sounds like you might have gotten a bad one though... :(
