lifeinchains
- Sep 29, 2004
Just set up my first watercooled system and i have a question about the pump. Its a danger den mag-II le and its making a noise that im not suite sure is normal. Its a vibration type noise that coming from inside the pump or at least thats what it sounds like. The best example i can come up with is that it makes the same noise as when you put baseball cards into the spokes of a bicycle.
Should I contact danger den about this?
