Im using the Swiftech MCP650 pump and my first set of fluids was a mix between water and the green hydrx(by swiftech) and the pump was relatively quiet. Couldnt even hardly tell it was on. Now I swapped out the coolant with fresh coolant and this time I am using a 3:1 mix of the clear innovatec protect pro and distilled water. But this time the pump is making a high pitch whine. Its nothing bad, but just a lot louder then before the change. Is that normal? I liked the quiet pump better
