Dayaks
- Feb 22, 2012
Anyone ever try putting the pump on the opposite end of the loop (res -> rad -> blocks -> pump -> res) so there's essentially a negative pressure across the loop? I realize centrifugal pumps are terrible at pulling so your flow might be a little lower, maybe you'll need an extra pump, and priming the loop would be fun.
If you had a "leak" you'd be sucking in air rather than pushing out water (onto the thousands in electronics). That's an attractive feature.
