This is my first watercooling setup.
I think my MCP350 failed during leak testing. It could be a variety of things that caused it.
Here are the details:
The Loop:
Res --> pump --> MCR320 --> Apogee cpu block --> Res. I don't think the loop is too restrictive. It was filled with distilled water and 5% antifreeze. The pump has a petra's top on it (which I notice now is leaking, even though the screws are as tight as I can make them) and the fluid isn't coming from the barbs.
There was A LOT of debris in the loop (white gunk) this time. I don't know why because, I cleaned out the radiator with vinegar (two washes about a month ago) before running it. Also it didn't look like much initally, but I left it for 5min and the res was full of it and the pump died (burning plastic smell). I opened up the pump, there was no debris in it, but the circuitry on the back was fried none the less; the green pcb melted exposing some copper which separated. I'm still not 100% it was the debris that caused it.
I think the thing that killed it was the fact that the res ports were probably partially blocked by this "gunk" preventing it from filling the pump. But I guess do to my inexperience I don't really know if this is the issue either.
I'm guessing the pump did run fine for around 5 min before it died.
I'm hoping one of you could help me narrow down the problem so that I don't make the same mistake again.
I am considering a MCP655 pump as a replacement (w/o the controller because I'm low on dough), but I'm not sure how well I can mount it in a already cramped Antec P180. I was also considering a MCP355, because I already have a petra's top, but I heard they have a high pitched whine. Right now both pumps cost pretty much the same.
Thanks
The Loop:
Thanks
