Pulsing LEDs question
andypnb
Hey all,
I am trying to make a mod thing and I though I would ask my questions here, where the experts can provide some advice.
This is what I am looking for:
I want a string of some 20-30 LEDs, to pulse from On to Off, slowly, and all of it run on batteries.
I have found this:
http://www.rabidhardware.net/?id=5
And thats essentially what I am looking for on a small scale. I need at least 20 LEDs , so much higher drainage, and I guess I can use a 9v battery or two as in that example. I can also use AA or AAA, as space permits it just fine.
Any advice on how I can accomplish this? Will 20-30 LEDs drain a 9v battery very quickly? A couple of them? Can I just do what that page does and simply put the LEDs in parallel?
Take a look at the schematic, and find R7--it's the one attached to the LED. See how R7 and the LED are in series? What you need to do is to make 20-30 of those LED-resistor strings, and connect them all in parallel with the original R7 and LED.
Keep in mind, though, that with 20-30 LEDs, you'll be pulling 400-600mA. That's not a huge amount of current, but it'll drain your 9V in well under an hour. For this kind of application, you probably want to get either a heftier battery pack or an AC/DC adapter.
I really only need it for about an hour at a time before I change the battery pack. Plus if I get 2 9v batteries, then I should have about a 2 hour window (duracell batteries say about 500mAh).
Also, since I am running 9v I would remove the first resistor R6 correct?
To be honest, I don't know why R6 is there in the first place. You *should* be fine without it, no matter what the supply voltage. The LM 1458 can handle supply voltages up to +/-18V, so the 9V shouldn't be a problem at all. Using two 9V batteries in parallel will more than double your run time. The less you drive a battery, the more total capacity you get.
