PSUs still blowing like mad
Yalpe
Hey guys,
Perhaps you should read this post, it will explain my situation. http://www.hardforum.com/showthread.php?t=1086297
Well, to recap, on my 3 PCs, 3 PSUs had blown up. By the end of the year, mine had died as well. I've replaced all of the Antec SmartPower 2.0 ones with Enermax NoiseTaker II 485W. I really though I had done the right thing and could put all of these problems behind me. But after I came back after the holiday period, I booted the PC once to find it dead the next day (shutdown overnight). 1 NoiseTaker down, 4 SmartPower down...
What the hell is up with nf4 ultra-d mobos? I didn't overclock like mad. My friend's rigs weren't even overclocked if at all. The only explanation that comes to my mind right now is A) there is a design defect in the mobos, B) not enough power. I'd expect a power supply that supports 2 CPUs and SLI/CF to be able to handle 1 cpu and a card... This is just wrong. I'll probably RMA the NoiseTaker since I've been using it for only 2 months but I'm feeling this problem will show up again.
And now that dfi-street is dying, I have lost pretty much all the information that was related to this problem. I did try the complete CMOS clear. Didn't work. However, I've succesfully started my PC with my friend's PSU (another noisetaker...) and the CMOS reset did work. I've jump started the powersupply as well, that worked but it won't boot the PC. Standby led is always on and DRAM led is always off.
If anyone has any idea, let me know, because this is hopeless.
With that many going down, I'm betting the power grid in your area (does your friend live nearby?) surges on a regular basis. Do you have to replace lightbulbs in the house frequently, or by chance do you get the higher voltage "industrial" type that some power companies sell to folks on the outlying areas?
yea, I'd tend to agree. I'd highly recommend investing in a small APC power backup system. It will protect your gear better than any normal surge protector/
Agree, but what he needs is a power conditioner or a ups with power "conditioning" the ability to modify/filter under or over input voltage to a stable output voltage with noise and transient supression.
For example:
http://www.tripplite.com/products/conditioners/index.cfm
some high end UPS units do have power conditioning but be sure to read the specs to make sure.
Correct me if I am wrong, but most APCs will condition the power in addition to providing surge protection.
With all of those power supplies going out... unless your capacitors are leaking or something is completely wrong with your board... I would suspect the power in your area is unstable.
Yep, thats by default, because if you have your equipment plugged into the battery backup ports of the APC / UPS, then you're literally always running off the battery vs the direct signal. aka pure power vs noisey power line.
Sorry, you are incorrect . A cheap UPS provides NO power conditioning ( and sometimes less surge protection than a really good surge protector) and thats the point I was trying to make.
Carefully read here the differences between the specs/features of the CS series (inexpensive home type UPS) and the server LS series.
http://www.apcc.com/products/category.cfm?id=13&subid=5
You will see that while the CS series does have some noise and surge protection it does not have the automatic voltage regulation (AVR) feature found in the more expensive UPS.
Few, if any, UPS's in the product category we are speaking about replace the utility AC all the time (which takes us back to conditioners), your battery life would be crap if it even were possible to recharge the battery as fast as it was being drained, and it is not.
The power is quite unstable for sure. When I was testing the PSU, with only the ATX cable and the few others on the board plugged, I switched the PSU on and the light went down... The building is quite old (still uses fuses instead of breakers). It might be a valid theory considering one of my friends live nearby. I'm not quite sure about the other one but I heard its fairly old in his area as well... I will start reading some info on APC/UPS. So you guys recommend nothing less then one with AVR?
Its quite interesting that they only fry when we turn the computer off. It either happens at runtime or overnight. My guess is that a surge a runtime could fry it but since it is running already it can keep up, however it wouldn't have the strenght to power up the system from cold.
I bet you turn the computer off by using the shutdown command or the button on the front, The power supply is still on, in standby and plugged into the wall. Unless you flip the switch on the power supply itself (around back where the AC cord plugs into the machine) the suppy is connected to the incoming AC 24x7 and susceptable to surges etc.
See the stickies.
YES you need the AVR function, it might be called something different by a different manufacturer.
Hmmm would be worthwhile to check the grounding in the wall receptacle as well if the building is really really old. Does the wall outlet have the holes for the 3 pin AC cords or just the 2 pin ?
WOW nice stickies, I gotta hang out in the power supply section more. Was going to say this thread needed to be moved there.
Super job on stickies. :cool:
Thanks.
I can't move the thread because this isn't my section but fugu can...or the OP can ask his question in the PSU forum. I have been getting a lot more questions about UPS's of late it seems.
See the stickies.
Yes I did turn off the computer using the shutdown command. I didn't think about it but you are right, its still on. I just checked rapidly and yes there is 3 holes, can't verify if they are connected behind the plug, I'm no electrician and I'd rather live ;) I was reading the stickies, lots of info in there. I might just RMA the powersupply and get something with AVR... Thanks for the help guys.
I could get this for 69$ CDN http://www.apcc.com/resource/include/techspec_index.cfm
However, even after reading the technical sheet twice, I can't find something that could relate to AVR.
Now there is this one for 121$. Its quite expensive but there is AVR
http://www.futureshop.ca/catalog/proddetail.asp?sku_id=0665000FS10077289&atab=&spviewed=&newlang=EN&logon=&langid=FR
Is the price difference really justified? Its quite sad to shell almost 200$ over a RMA and this hehe. But I really don't want it to blow again.
you are wise beyond your years :D
If you have the three holes you are probally OK. Building inspectors and electricians dont usually let improper grounding slip by as you pointed out, someone could get killed.
I just read your other post, sorry, should have done that from the start. I now understand that all the supplies were antec bought same time and place probally, and all not in your house/apartment but your friend lives nearby. It could have been a bad batch of PS, since you got them all the same time. But the new rma one going quickly still makes me suspect your AC power.
I really think the AVS is worth it with all the trouble you been having, I have built a couple hundred PC's and havent had near the trouble you been having with power supplies. At the very worst case you will eliminate a possible cause and allow you to zero in the real problem but I am betting this will do the trick.
If its not a bad batch, and its not your AC power, only other thing I can think of is a short created in mounting the motherboard (screws overtightened or mounting post misaligned and hitting a trace) and it seems that would cause a problem from the word go, so I doubt that. It would have to be something you did on all three machines and that just doesnt seem likely as your level of expertise seems high.
Best of luck.
Yes I did buy the first 3 at the same time. They were included with the Sonata II cases. At first I though there was not enough power so I didn't RMA, I bought a SP 2.0 500W instead, which died a few months later at the same time or close to my other friends 450W. I bought them both Enermax NoiseTaker II thinking that Antec was the devil. I was a bit worried about electrical installations because at that time I was living in a less then 10 years old building and I hadn't had any problem with my 450W. (note that I was OCing a lot more and I had an 1800xt instead of a x800 pro) I moved in september, my 450W died in november. Bought another enermax since it was cheap and seemed like it could do the job. Now it died in january. On my side it might be linked with me plugging in a small freezer on the powerbar... Never thought it could hurt, but then again it might not be the cause. Anyways, I'll get the APC and RMA the NoiseTaker II, I don't use the freezer anymore so I should be problem free for a while (I hope).
Could certainly have been the freezer. It could be throwing large surges on the power strip every time the compressor cycles.
I use a power conditioner (no UPS features) I bought many years ago to protect my main/expensive rig. Big heavy expensive box, but I think it's been a good investment. Strongly recommended for areas/buildings with power problems.
Better yet buy a PSU without Fuhjyyu caps... Their failure is well documented online.
Yes the Antec based CWT SmartPowers and TruePowers can have issues with their Fuhjyyu caps but it is due to the cooling system employed by Antec. Other PSU brands using the same CWT models and/or Fuhjyyu caps with more aggressive cooling setups work fine. Fuhjyyu doesn't make the best caps in the world but they aren't the worst...and even PC Power and Cooling has what aren't widely considered good caps (Teapo) in their Win-Tact made Turbo-Cools ;) But they work fine because they are properly cooled.
Yes, agreed, I left that part out, but posted elswhere here. Oklahoma Wolf has described this before and has described the mod to get the air flowing in those antecs. Not that the big fat wiring harness helps any either ;)
