Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I had a CompUSA supply once, well before I saw the light. I do believe it managed to kill a stick of crucial ram. (good thing for lifetime warranties).
yea.. once I told a customer that they needed a new power supply, and to go ask comp usa for a 250watt .. and she came back with an AT 250watt (not atx..) just when you think they can't screw it up....
I picked up an Ultra XConnect 500W today for $99. Thats around $10-20 cheaper than have seen it online. Most reviews are good. Had some trouble w/ and Antec 550w and this ones ok so far. Wiring is great.
I would buy an Antec, AT MINIMUM. CUSA PSU's are shit; they sell hundreds, and maybe 15% come back- almost immediatly that is- and they don't care. Look for SParkle for an excellent, rock solid PSU for not too much money; a Fortron (whose guts the Sparkle's have) is a little better. You can certainly spend as much as you want on a PSU though....
CompUSA brand PSUs come from many manufacturers. The brand may be listed as FMI, but that's just a distributor, and FMI's distributor, 4-star, which told me that the supplier changed about every week but was Win-tact when I called (very good -- PC Power & Cooling uses them for some PSUs), although I've seen others that were definitely Leadmans (Powmax, Robanton).
