psu wire gauge
Jo3999
Hi, i am looking at buying a corsair ax1200i but i want to sleeve the cables myself so does anyone know if the wires if the wire used in the corsair ax1200i are 18 gauge, if not could someone please recommend another reliable psu with all 18 gauge wire,
Thanks.
Why do you need 18 gauge specifically? I am sure any decent PSU will come with as thick of cables as required for it's power output.
because i am going to sleeve them and on my current psu the wire is 16 gauge and it does not fit in the atx connector
I see, and I am assuming you want the sleeve to come all the way into the connector then, as opposed to heat shrinking it just before the connector.
In that case, no, I don't know any off the top of my head.
