kevineugenius
- Dec 9, 2006
I understand that they're not perfect and watts aren't the only thing that matters. However, I just looked through a couple for a bit of baseline info and here is what I got:
Outvision-based calculator: 497W
Newegg's calculator: 655W
Asus' calculator: 950W
So, that basically covers every single power supply on the market right now... How do you *really* know how much power you need? I'm currently running a 700W and it seems to be problem-free, but I have a mobo issue and they won't replace the mobo until I've ruled out power supply problems for certain.
2600k
Gigabyte z68 UD4
G.Skill 2x4gb 1333
2x AMD 6870 1gb
1x 10k SATA
1x 7.2k SATA
1x Bluray SATA
1x PCI audio
2x CPU fans
3x oversize case fans (HAF 922)
I personally think moving up a couple hundred watts is the smart thing to do, but I've also had people on this very forum suggest that the 700 that I have is more than I need.
2600k
Gigabyte z68 UD4
G.Skill 2x4gb 1333
2x AMD 6870 1gb
1x 10k SATA
1x 7.2k SATA
1x Bluray SATA
1x PCI audio
2x CPU fans
