No fanless mode, not fully modular, and a crappy ADDA fan.
If you really want a G-Series look into one of Seasonic's OEM's.
I also paid $90 for it which is even $10 cheaper than the G-Series.At least it'll outlast your V700's FDB (read: sleeve) bearing fan![]()
There are G-Series 650W OEM's for ~$110 which do everything I described. The HX650 has been as low as $80.The OP undoubtedly is looking for a mid-range psu, not a high-end one
That's true, but only slightly.I would get a CX600M, they are great PSUs and cheaper then the seasonics you guys are recommending.
Look no further. Here you go:
http://www.newegg.com/Product/Produ...a&cm_sp=&AID=10440897&PID=3891137&SID=rewrite
Corsair fully modular HX-750 for $89.99 (AR) shipped. That's a very solid deal & it's a well made Channel-Well PSU. BTW...I bought a CX-430 PSU (for an XP build) a couple of months back & received my $20.00 rebate in less then 3 weeks from Corsair.
