psu voltages + other
MoDsOuRcEdOtNeT
Had a trouble with my houses wireing shorting out and now Im having problems. Opon post it would have one long beep so I reseated the memory and cleared the cmos and it booted, but now my voltages seem off is
+3.3 is 3.42
+5 is 5.02
+12 is 12.41
My socket sensor is reporting LA (down arrow) lodq' stqd
And my cpu sensor is reporting 18 degrees (air cooling)
Then my BIOS froze up so I just shut it off.
Looking like cpu might be dead?
Your voltages are all in spec, what were they before?
Is it giving you problems now? are they fluctuating? Did you check them with a DMM?
Im scared to boot it again :p I was hoping to take it to my local computer shop for testing this week. And sorry I dont know what a DMM is. But they are fluctuating slightly last i checked (normal as far as I know)
