I just recently built a new computer (3 days ago) after getting it all set up and installed and updated i started poking around with speedfan and cpuz and the like. Well, i noticed something weird.. I'm getting 11.09 according to speed fan and 11. 704 volts according to bios instead of 12 volts.
When i got home from work today i checked the values of all the output plugs on my PSU except the 24 pin one for the motherboard (I did check the 8 pin that goes above the CPU). All of these came out to be 12v or 12.20v (the 12.20 came from he 8 pin above the cpu).
Other values are fine, 5v is fine and 3.3v is fine according to bios. Speed fan doesnt show those also
I'm curious if this is as huge of deal as i think it is.
Is there a better program for checking voltages than speed fan? I havent done a search since i just got home.
My power supply is: SILVERSTONE ST70F 700W ATX12V / EPS12V
Mother board is: ASUS P5Q Pro LGA 775 Intel P45 ATX Intel Motherboard
Nothing is overclocked, and i only have enough of the modular cables plugged in to power what i need so theres a bunch of open slots.
