PSU upside down?
Blasterboy460
my freind bought an antec true blue PSU and it works great, but when installing it it wold only line up correctly with the holes if done upside down. so now the second fan is facing the top of the case. how do i fix this, any tutorials?
Just drill some holes in the case to line up with the power supply. You may have to cut out a bit more of the metal for the fan and the power connector, though.
