I have a XFR XTR 550w, but I want to upgrade to something with more headroom. Thinking something around 750w. Any recommendations??
What do you intend to power?
My Silverstone Platinum 1500w that powers my 3770k, GTX 680 and 3 hard drives would like to pick a bone with you.Kinda important. Components today are taking less power not more. When I see people buying a 1kw PSU for a typical new desktop PC I just facepalm.
Yeah, when I said typical I was not including SLI. Should've known it wasn't clear.
fair enough. We agree then.
yea, I have a recommendation ... look it up yourself. You can add/remove items as desired then calculate how many watts you need to use ....... PS Calculator
compared to what?Those are not very accurate.
Here's the deal:compared to what?
Did you even try the calculator? Hint it doesn't say anything near the 850w, try 1/4 of that.Here's the deal:
The values that are used in the calculations are based solely on their peak power draw and their TDP. However, today's components output far more heat than their old-generation forebears per watt consumed. As a result, the recommended minimum wattage as indicated by such a calculator would have been far higher than what those components really draw. (Anyone really need an 850W PSU for a cheap dual-core CPU with only integrated IGP?)
That calculator and at least 1 other seems to be accurate. Now Newegg calculator is drunk
I haven't used PSU calculators recently but historically they have been inaccurate. The inaccuracy varies depending on component selection. Getting power draw numbers from tech review sites and adding them up yourself is more accurate.
