PSU tester
smut
will a PSU tester be able to turn on the PSU without it being on a motherboard? THe reason I ask is because I m going to need to leak test my water loop but obviously I dont wanna hook it up the motherboard to run. I know the wire trick to turn it on but I'd rather use a PSU tester to turn it on, its easier for me. Id be getting a cheaper one if its possible, not spending an arm and a leg or I will just do the 2 wire trick.
Edit: I found a little tool at frozencpu that is cheap that will help me out.
