Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Motherboard Monitor (MBM) can log you various voltage rails as reported by the SMBus, however they can be "off" (most hardware monitors supplied by the mobo manufacturer do the same as does your BIOS)
a multimeter, while under load is the normal proceedure
but with the requirements of modern components (stability) logging with a multimeter under a dynamic load is the foolproof solution
