PSU Suggestion
daphoking
I looking for a sub 70 dollar PSU for a new system I'm thinking of building. Here are the specs of the system straight from Newegg:
- ASUS M2NPV-VM Socket AM2 NVIDIA GeForce 6150 Micro ATX AMD Motherboard - Retail
- AMD Athlon 64 X2 3800+ Manchester 2000MHz HT Socket 939 Dual Core Processor Model ADA3800BVBOX - Retail
- G.SKILL 1GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Unbuffered System Memory Model F2-6400PHU1-1GBNR - Retail
- Seagate Barracuda 7200.9 SATA NCQ 3Gb/s ST3160812AS 160GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
_Korruption_ said:
Again, like in the other thread, why? You can get a way better choice than that basic Enhance.
Are you going to be using this in an mATX case?
http://www.newegg.com/Product/Product.asp?Item=N82E16817388003
My other thread was a Enermax Noisetaker and both the Noisetaker and the Enhance I posted are very good, I don't see a reason to buy a $70, 450W PSU if your only going to use 200W of it at peak loads.
