PSU Sleeving
EnderXC
I'm looking to clean up the wires in my case, but the question is will I void my PSU's warranty if I Sleeve it? It's a Forton Source. Thanks.
Yes, it will void your warranty. Especially if there's a sticker that says "Void warranty if broken". That sticker is usually one way to get into your PSU.
Buy some of my split loom (posted in the FS/FT area) and loom your PSU with that. It won't void your warranty since you don't need to open the power supply or remove any connectors.
Yeah, as long as you dont crack the PSU casing open you should be fine. I sleeved my PSU without doing so and it came out great!, just make sure if you need warranty work done, to remove the sleeving first ;)
