I think what he's suggesting is taking the wires out of the molex connector, sleeving it from that end and then putting them back in. That way, you never have to disconnect the SATA plug.SeaDonkey said:PSU------MOLEX--------SATA........ <thats the way it goes.
My problem is I have no way to get the sleeving over the sata connector, and it's on the end. The only way I see to do it would be cut the sata connector then solder.
