Looking at the ratings curves for efficiency vs load, I wonder if a 850 would produce less heat than a 650, and draw less power?
Suppose my rig draws a steady 400 watts doing some activity. A 400w Gold PSU would be at nearly 100% and lower efficiency than a 800w Gold PSU running at 50% load in the same rig.
Now yes, if I have a 400w load, I would pick a 650 Gold PSU probably for that rig. But even still, a 650 would put me at 75% load during that activity.
So would a PSU, double (100%) times the load, draw less power from the outlet and put out less heat than a PSU that is 50% of the load? (give the same Gold rating)
I know this is a very specific example, I'm just looking at the math against the curves I see about 80+ specs.
