- Apr 7, 2006
Ok so i have seen where you can stick a paperclip in the main ATX connector to turn on the PSU, but can you do the opposite?
What i would like to do is have the rocker switch be the on/off switch for my mobo.
Would jumping a couple of the pins on the mobo(where the reset/pwr switch is) do the trick?
I am not running windows are anything like that so im not worried about hard shutdowns.
