astralsolace
- Mar 3, 2006
I've read through the FAQs and general information (as well as tried to use some of the less-than-stellar calculators), and it all seems fairly complicated--but I'm wondering:
What kind of PSU would be required for the following setup?:
Intel Core 2 Quad Q6600 - 2.4GHz
( http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017)
Tuniq T-120-LFB 120mm CPU Cooler
(http://www.newegg.com/Product/Product.aspx?Item=N82E16835154002)
Abit IP35 Pro Motherboard
(http://www.newegg.com/Product/Product.aspx?Item=N82E16813127030&Tpk=Abit+IP35+pro )
4x1GB Corsair XMS2 4-4-4-12 4CAS DDR2-800/PC-6400, planning on overclocking to DDR2-1066. ( http://www.newegg.com/Product/Product.aspx?Item=N82E16820145034 ) x2
GIGABYTE GV-NX88T512HP GeForce 8800GT 512MB 256-bit GDDR3 PCI Express 2.0 HDCP Ready
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125081&Tpk=GIGABYTE+GV-NX88T512HP+8800GT
2x Seagate Barracuda drives--not sure which model number.
1x Sony DVD-RW drive
3x case fans (one front, one rear).
I've heard estimates of about 500w. But the drain, max, on the CPU is around 100-110, video card is around 110, RAM is around 40, drives are around 40, optical drive is around 25--fans are around 6 total, this equals 331. 25 or so (bad guess?) for the motherboard itself. Around 356. Maybe 10 more for an audigy 2 sound card. So 360.
Wouldn't a 420w power source (from Alienware, no idea which actual brand) suffice? How would I know? What if I wanted to overclock the CPU to around 3.0GHz?
Thanks for any and all input.
