PSU Requirement for Atom D525
JimmyNeutron
I'm trying to determine the maximum wattage I need on a PSU for the following hardware:
Gigabyte GA-D525TUD or an ASRock A330ION
1 x 2.5" Seagate Momentus 5400RPM
1 x 3.5" WD Green 2TB 5400RPM
1 x Wireless N USB Adapter
1 x USB 2.5" HDD
I check some of the PSU calculators and they say I need a 100W+ PSU. Not sure if that's accurate.
I was hoping I can get away w/ a small picoPSU of about 60W using the following:
http://www.mini-box.com/picoPSU-120-power-kit
Would the Atom D525 be overkill for this PSU? What about if I move over to the Atom 330 processor that uses less power?
This computer will primary be used as a FTP server and NVR for my security cameras.
Any feedback would be appreciated!
Thanks!
I honestly think that the 35w that fox quoted is on the high side
Posted via Mobile Device
Edit. at least for a d510 without ion
If the ITX motherboard is equipped w/ an ION graphics, how much wattage does that alone draw and what's the PSU capacity I need to jump to now w/ an ION graphic chipset?
Thanks!
That PSU would be fine.
ION uses a bit more power. Not counting ION, the D525 uses LESS power than the 330. Yes, I know the TDP is higher, but the 330 requires either the 945GC or the ION chipsets which end up using more power as a platform.
