PSU recommendation for Q6600
icephoenix
Can someone please recommend me a very good PSU for Q6600, that probably will run almost 24/7. There also will be something like 4 HDDs in the rig, and middle level GPU.
Well, depends on the "mid level" GPU, really. Also depends if you'd be overclocking at all.
Just guessing, I'd say something in the 500-600 watt range, a quality unit. Silverstone, Corsair, Seasonic, PC Power and Cooling, or an Xclio if you're on a budget.
No overclocking for sure.
And I have no idea what is mid-level GPU now... some thing simple and around $100 :)
Though it'll be lovely to have something that will allow to put more load on it in the future...
