Psu question
Splat
am getting a a8n-sli and it says a atx 2.0 psu is needed will a Hiper Triple Fan 525W ATX2.2 PSU suffice?
well according to the specs
http://www.hipergroup.com/4s525s.pdf
it is a compliant supply as far as it goes, having both a 24 pin main power connector
and a PCI-E 6 pin aux Video Card connector
but it has only one of those so if the cards each require one....
also it has 20A on the +12V1 rail and 17A on the +12V2 rail
if that will suffice for your config at your likely operation temperature
