Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Should I even bother discharging the capacitators? Will I damage them if I use a screw driver to do it? Or should I just be careful and not discharge them?
You should always discharge the capacitors, if only as a good habit in case you get careless. Simply shut off the computer using your OS, unplug the AC power cable, and press the power button on your case. You might notice an LED flicker or a fan twitch. That happens because the capacitors and inductors are "drained." Now it is pretty safe to open up your power supply. Don't ever use a screwdriver to short a capacitor. It can ruin the capacitor and/or screwdriver!
Just press the power button a couple of times then you will be fine. Hell I took PSU's apart without doing that and touched every possible thing and I'm still alive
I don't know whether it matters or not, but it seems to me that because the power button is soft power, not a real switch to turn on the juice, it's better to have the system running and kill the AC, rather than trying to start the machine with no AC. Think about it this way: Since the mobo uses +5VSB for powereing on, if the capacators feeding the +5VSB are dischaged before the other ones, the system will not start, yet still might have some un-discharged capacitors for other rails.
