psu problems
Zucharn
I was wondering if my power supply is too small. It is a 320w made by on2 tech.
My system specs are: athlon xp 2600+ barton, abit nf7-s rev. 2, sapphire 9600xt, a generic 50x cd-rom drive, and a 40 gig maxtor hard drive. I also have 2 case fans.
My problem is that when I tried adding an 80gig samsung drive in addition to my current one, the system would crash extremely often during periods of high hard drive access, and the drives made loud clicking noises. The problems stopped when I disconnected the second drive. However, the drive worked fine in another computer that has an enermax 450w psu.
Sounds like it.....but to be sure you need to switch another PSU into your system. Can you borrow that enermax?
If not give us a budget (not $20), and the full system specs.
Wattage to small, nah. Piece of crap, quite possibly.
Had about 8-10 drives, 9800pro, OCed P4 2.4C running stable as anything on a system with a Zalman 300W or something like that. Quite stable. This isn't a size thing, it's the fact that the wattage sticker they slapped on it isn't very indicitive of the unit's functional power or quality.
I can't switch the enermax in because it's in my dad's computer about 400 miles away.
My full system specs are the 320w psu, an athlon xp 2600+ barton at stock speeds, a sapphire 9600xt, a no name cdrw, a no name cdrom, abit nf7-n motherboard, a 40gig maxtor drive, and an 80gig samsung drive, and an old 3com nic, and 2 antec case fans. whole setup is in an antec full tower, i think it is the plusview thingy.
my budget for a new psu is about $50, because my monitor seems to be dying as well and i'm saving about $150 for a new 1.
i got my psu because I had $20 and the psu I was planning to put in fell out of the car and smashed on the asphalt. so I went into the town electronics store and asked what their cheapest atx psu was.
Ok I was hoping we could swap to be sure there wasn't another item causing the issue. Look at these PSU's.....feel free to shop them around for a better price:
http://www.newegg.com/Product/Product.asp?Item=N82E16817103935 $55
http://www.newegg.com/Product/Product.asp?Item=N82E16817104936 $55
http://www.newegg.com/Product/Product.asp?Item=N82E16817103444 $44
with the enermax, it says 14A on the 12V rail, and it says dual 12V rails, i'm just looking for clarification on wether it means 2 14A rails, or 14A spread between 2 rails.
Ahhhhh.....newegg. 2 12v's, one with 14amps...one with 13amps.
when I went to enermax's website and looked up the specs, the website says that each 12v rail is 18A. are they different versions of the psu? because they have the same model #.
There can be different revisions.
