Hi,
Currently I have a Raidmax Storm Case (http://www.newegg.com/app/ViewProductDesc.asp?description=11-156-132&depa=0)
I am using the PSU it came with, which is only a 420 watt, here's a link to its stats:
http://www.newegg.com/app/Showimage.../11-156-132-09.JPG&CurImage=11-156-132-11.JPG
Recently I have had a few times while playing computer games where the computer just resets. It will shut off and then restart all by itself. At first I thought it might be a ram problem bc I was also getting "memory can't be read" messages so I upped the voltage on the ram (per Kingston's Tech Supports instruction). I haven't gotten any of those messages but the computer will still sometimes shut itself off and then reboot, but only when I am playing games. I think this might be bc the PSU is inadequate, bc while I am gaming the fans in my case speed up, the graphics card is working harder, etc. I don't think the stock Raidmax PSU is that great (look at the amps it gets for the 12 V connection).
Could anyone suggest a good PSU for my computer or at least a way to test if it is in fact my PSU that is causing the computer to reboot.
I am running:
P4 3.2 gigahertz
1 gig of DDR 3200 RAM
200 gig Seagate Harddrive
A DVD Burner, a CD Drive, a Floppy Drive
6600 GT Graphics Card
Four 80 mm stock fans
And a Gigabyte 8I915P Duo Pro mobo
I am running:
P4 3.2 gigahertz
