julianbautista87
- Sep 27, 2010
Hello,
I have this pc:
- Asus m4a785 tdv evo
- Athlon x4 635
- HD5770 vapor-x
- 1 x Hard drive seagate 1500 GB
- 1 x 2 GB ddr3 markvision 1333Mhz
- 3 x 80mm 12V fan
- Thermaltake tr2 600W
I had tested the power consumption of my pc, and I tested my pc with gta4, cod5.
I tested the current in the 120V ac line, whit a small tester.
I got confusing results, When my pc is iddle, the tester shows ~ 0.8 A
When Im playing cod5 whit all max, the tester shows ~ 1.1 A
When Im doing a benchmark whit gta4, the tester shows ~ 1.2 A
power consumption = V * I = 120 V rms * 1.2 A rms = 144 W max.
why? I mean, what am I doing wrong? is it true the psu is only getting 144 W? I dont think so, but I hope you can tell me .
thanks for reading.
-ammeter : multimeter UNI-T UT33A
- I messured the current like this:
in this draw, the lamp is the pc, and the battery is the 120V line. and the tester was messuring AC current.
my pc should be getting more power, I mean, the graphic card + processor should get 75 + 90 W = 165 W ONLY those parts, so... what am I doing wrong?
I have this pc:
- Athlon x4 635
- HD5770 vapor-x
- 3 x 80mm 12V fan
thanks for reading.
