I've done the paper click quite a few times to test a psu, or a fan or something to see if it works. Green to black, even the same pin. Well I am at work and they were giving away free computer parts and I grabbed an Antec 300W psu I was going to take, and I decided to check it if was good, and did the trick, had it on the correct wires...
When I plugged it in sparks flew, and it burnt up bad (for somreason I felt this would happen so I was ready to pull the plug).. I know I had the trick on the correct wires, but I wouldn't use that paperclip trick again.
What do you think?
What do you think?
