A 510W PCP&C PSU is more like a 700W+ Antec supply. PCP&C tests their power supplies at 50C whereas other companies like Antec rate their PSU's at 25C in an unrealistic vacuum environment. The ability for a conductor to promote the flow of electricity at higher temperatures is severely less than at a lower temperature; hence, if the Antec was actually rated at 50C it would probably carry something closer to 350W of power (and the same would go for the current on the various rails as well).pvtgoose said:I think the neo would be fine. I seen no difference in 510w and 480, but the neopower is antecs top of the line, I would think you would be fine.
You're probably going to have to have it shipped to you from California.Hate_Bot said:Does anyone know where I could find a PCP&C PSU in canada? Ive been having a tough time finding one...
Yeah, I just found a review on it:fuzzy34 said:looks good, but that doesnt say much.....hopefully someone will know something more than i do on this![]()
Ice Czar said:likely any of those would be fine
but yes the PCP&C is the superior supply and IMO worth the money considering the SLi investment
its also the only Nvidia SLi certified ATX12V formfactor supply
(there are 2 other EPS12V supplies, one of those also a PCP&C)
