PSU ok for 8800GT?
currently have a Corsair HX520, specs: +3.3@24A,+5V@24A,+12V1@18A,+12V2@18A,+12V3@18A,- 12V@0.8A,+5VSB@3A
i'm replacing a dead 7600GT, so an upgrade is in order.
System includes,
-s939 AMD X2 4600+
-nforce 4 sli mobo(gigabyte mfg)
-2GB DDR 400 (2x1gb sticks)
-Audigy Xfi
-FireWire 400 PCI Express x1 card(uses external 4 pin molex power)
-3x sata hdds
-1x dvd-r/w
-antec 900 case(5x120mm fans, 1x200mm)
Nothing overclocked, all stock timings.
would i have any issues with this psu? i'm replacing a dead 7600gt, with a new 8800 GT card, probably the OC bfg model.
also with the case (antec 900), anyone have clearance problems with the GT?
System includes,
-s939 AMD X2 4600+
-Audigy Xfi
-3x sata hdds
-1x dvd-r/w
No. That should be enough. That's a very good PSU.
System includes,
-s939 AMD X2 4600+
-Audigy Xfi
-3x sata hdds
-1x dvd-r/w
That PSU could probably handle TWO 8800GTs with no problem whatsoever.
As for the Antec Nine Hundred the only problem you might run into is with the positioning of your hard drives. You MIGHT need to move your HDD to a different spot if it's in the way.
Hell I had an Ultra in my Nine Hundred. :D
