mastaBlasta
- Jan 27, 2011
My issue is simple yet very frustrating.
I live in a small apartment in an old building and the maximum current coming to my fuse box is 20 Amps. Yes I = 20A! Two circuits, 10 amps each.
I am building a new SB machine with specs similar to other folks here, and have gotten stuck on the power supply. Many of the 600W+ PS say 10 amp input which is simply too high.
I'm hoping that that's not true, or that it only sucks in 10 Amps under ultra heavy load, and under normal use is 5A or something.
What kind of average amp use can i expect from most mainstream PS. Is there some kind of hardware solution, like an adapter of sorts that will up the ampage by using more voltage?
Any help is greatly appreciated.
