psu help?
sumofatguy
ok, i need a little help choosing my power supply... i dont know if i should get a dual rail power supply or not... and how much amps will i need for the 12v rail right now? my setup is
asrock dual sata2 (20 pin)
2x512 kingston ddr (2 more in the near future)
opteron 146
bfg 6600gt agp
1 western digital sata2 250 gb drive
1 ide 40 gig drive
1 dvd rw
1 dvd drive
zalman 7000b alcu cpu heatsink
2x 80mm case fans
ok right now i have a 400w peice of poo maxpower with 14A on the +12v rail. i was wondering with that setup what i would need for the 12v rail for a new ps, and whether or not to go dual rail or not. thanks guys
How far do you plan to upgrade before replacing the PSU? What is your budget?
well i was thinking about buying an antec p160 case after christmas and a psu to go with it... the only upgrading other than taht for hardware in the near future would be 2 more 512 sticks of ram... i dont really want to spend much more than i dunno $75 on it cause im probably going have to get it shipped to me here in canada which won't be too cheap... and with the case that will be a few bucks
