PSU HELP
-h2o-
OK this is my currents spec
X1900xtx Graphics card
Corsair 2GB DDR2 XMS2-6400C4 TwinX (2x1GB) (MY-108-CS)
Western Digital Raptor 74GB S150 16MB 10000RPM
Intel Core 2 DUO E6700
Gigabyte GA_965P_DQ6
I currently own the Aspire 500w Concord addition. I have had so many comments that the aspire PSU are crap. I am a total noob to PSU and i was wondering if you could recommend me a good psu with the correct tolerances and the such. I am quite strict on a budget after buying this rig and need to know quickly so I can send my aspire PSU back.
if you recon i should keep it and its not worth the effort please say so,
Cheers
no its just the psu i am looking to upgrade.
I would like to keep the psu under £60 is if possible ($100 I think)
i dont intend to overclock.
I am not sure if i am just being fussy or if it would be highly recommended that I upgraded my PSU. have had mixed reactions
Discontinued and mediocre performance to begin with.
OCZ going to FSP was the smartest move they've made.
FSP? sorry like i sadi my knowledge on psu is limited.
pretty much decided on the psu. I just want to check with you experts that the psu is suffecient and practicle enough.
1900xtx i know need at least 450w
conroe E6700 ??????????
XMS2 DDR2 800MHz 2GB (not a lot?)
3 HardDrives
Fan controller
3 Fans
UV Cathode
DVDRW drive
520watt PSU
Link to PSU i am getting
