PSU for the TJ09
TalonMan
I am looking for a PSU to go inside a TJ09's case. Under the PSU is the air intake in this case. Ideally I would like the air to pull air from the bottom of the PSU, and jet directly out the back never entering the case. PSU's that draw from the bottom are hard to find. I also would like it to be modular, or semi-modular, connections. It needs to be 850w or higher, and will be powering an IP-35 Pro mobo. Does this creature exist? It would need decent reviews too! ;)
Should I get hung up on finding a PSU that's intake is under the supply, and having a supply that does not draw from the bottom, and vent out the back? It just seems like it would keep so much extra heet out of the case to me.
I wish I could find this mythological supply.
Thanks.. Getting ready to pull the trigger on my 'mid life Crysis' machine, and want it to be just right. :)
