PSU for PII X4 920?
RCGA
I'm building a PII X4 920, with one HD (WD 640GB), a MSI 4830 GPU and 4gb of ram.
I have no intention of overclocking this btw
How many watts do I need? 400?
You could probably get by on a 400W PSU, although I would recommend something in the range of 450-500W just to have a little headroom. Here are a few great options:
Corsair VX450 450W: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139003
Antec Earthwatts 500W: http://www.newegg.com/Product/Product.aspx?Item=N82E16817371007
Seasonic SS-500ET 500W: http://www.newegg.com/Product/Product.aspx?Item=N82E16817151069
BFG LS-550 550W: http://www.newegg.com/Product/Product.aspx?Item=N82E16817702008
920=125w hd = about 10w full load, motherboard you avg out to about 35-50w so your probably looking at around 200-250w total if you put your entire system under full load.. so yeah a 400w with a good 12v rail would work.. but id go with one of zero82z's recommendations if you dont already have a psu..
All good recommendations.
Personally I would go with either the Antec Earthwatts as it is rated at 50C, or for the Seasonic for its Quiet operation. If money is tight you could also safely "step-down" a level, without hurting anything, but these give lots of overhead & plenty of room to grow!
Always Build with the Best,
Dave:)
