PSU for HD7970
tjbp
Hello,
I have and Radeon HD 7970 Ghz Edition. My PSU states that it has two 12V 19Amp rails, and I know that this means that the current limit is probably combined and capped at 38A.
The AMD website spec page says that it needs 150W and 75W from an 8-pin connector and 6-pin connector respectively. That means that the card needs at least 18.75A at 12V (I think). I expect that my PSU has sufficient power.
However, I am having problems that seem consistent with insufficient power. When I start Tomb Raider up I have significant artifacts and the computer will immediately reboot before the main menu is reached. The menu screens in Crysis 3 will load up correctly, however, once any 3D is loaded the computer will immediately restart without warning.
The graphics card is brand new, however, the PSU is 3 years old.
Does anyone have any suggestions?
We are going to need more information on your PSU before we can help.
In a nutshell, you should have a "high quality" PSU with at least 550w when using a 7970 GPU.
Hi,
The PSU itself is an 800W Atrix, Model: 800T. It was a fairly decent PSU when I bought it, the numbers appear to add up, yet lack of power seems the culprit.
I know that my 3 year old Antec True Power 650 powers my system just fine, I put my 7970 in Wednesday and played some battlefield 4 last night.
I have a lot of stuff in my machine, 2 SSD's, 7 spinning hard drives, corsair h60 cooler with 2 fans, and the 3 large fans that come in the HAF-932
Along with the i7 3770k and 16gb of ram.
My system is not that power hungry.
A single spinning hard drive, DVD Drive, 8gb Corsair RAM, Core i7-2600K.
I have 4 Chassis fans.
My PSU provides two 6-pin connectors for a PCI-e component. I have hooked one 6-pin connector up to the 7970. I have then had to use an adapter to change two Molex connectors to an 8-pin connection.
I sadly have to say that your PSU doesn't have the enough power to feed your card, a decent 800W will deliver in the 12V Rail at least 60A(720W).. and your PSU have 19A in 2 Rails thats not mean it have a combined of 38A(456W) it will be more or less 32-34A (384-408)..and thats hoping the PSU can deliver the labeled wattage of 2 19A on 12V Rail... a PSU with dual triple or quadra 12V Rails never scale totally, thats why the best PSUs have a single and stronger 12V Rail. my secondary/Work PC have a crappy cheap thermaltake TR2-700 700W PSU and it have 52A(624W) in the 12V Rail wich its fairly correct for a PSU of that wattage. yes your problem its due to lack of power PSU that cant deliver the labeled wattage wich its really bad to be a 800W PSU.
