PSU for GTX 280 SLI
phinix
I'm not sure if there was same thread before, but need to ask:
what PSU is enough for two GTX 280 in SLI?
Do I really need 80-850W PSU? What about 750W? Most reviews says one GTX280 takes max 250W in 100% load, so 500W would be anough for SLI, right? So taking standard efficiency of PSU - 80% of PSU power - 750W will have 600W. Would that be enough?
Like for example Corsair 750W?
Second question: I have 500W Enermax Liberty - is that enough for one GTX280?
Here you can see that GTX280 takes a bit more over 313W load and 508W in SLI under load...
That would mean that 750W PSU could be enough for GTX280 in SLI...
Did anyone tried SLI on 750-800W PSU????
System # 1 in my sig is running on a PC P&C 750. In addition to the cards, there are 5 HDs and 3 opticals. It's currenly running 3 ea folding@home clients on the cpu and 2 ea folding@home on the 280 gtx's so it's got a really good load. No problems at all, but I can't quantify the load on the gfx cards that folding puts on them. I'm reasonably sure it's a pretty good one however. Maybe somebody else can answer that.
So, looks like750W.. 800W would be fine, even if I'm going to OC cpu and gpus. I will use 1, maybe max 2 hdds, 1 slim dvd and watercooling loop.
Would I be ok with 800W then???
A good 800W might cut it. Personally speaking, I have had PSU issues in the past, though, including, most recently, a Cooler Master Real Power Pro 750W that didn't like one GTX 280 (the high-pitched screech, and occasional lock-ups if I let that go on for a few minutes), let alone two.
So I went with the Corsair 1000W when I decided to go SLI with the 280s. No issues whatsoever.
tri SLI on 800W??!!
wow...
Did anyone see Thermaltake ToughPower 850W Modular? I cannot find t in any shops...
Forgot to add I'm in UK...
When you click to buy Thermaltake you will see its cheaper than Corsair. Plus Corsair is way longer than TT.I dont know why but cannot find TT in any shops in UK...:((
$8 cheaper after shipping. I previously had a link to Newegg so the Corsair was cheaper. After a quick search eWiz had one of the better deals.The Corsair is still a no-brainer IMO.
Special order one.
The Thermaltake 850 has 62A on the +12V rail, and the Corsair TX750 has 60A on the +12V rail.
If you can't going to get by with 60A on the TX750, and you don't want to buy the HX1000 for whatever reason, then you should be looking for an 800-900W PSU with at least 65-70A on the +12V rail combined.
